Indicators flash more quickly on one side.
Just noticed this today - indicators on left flash slower than those on the right. Since they both use the same unit is this a resistance problem with the left side wiring?
Re: Indicators flash more quickly on one side.
I'd say it's a grounding problem, or miss-matched wattage bulbs.
Thanks Dave - will check all connections and see if this helps.
Fully charged battery?
Are both flashing on the 'fast' side? Typical of a burned out bulb. (On the 'fast' side.)
Battery fully charged and no blown bulbs so will check all connections for corrosion etc.
