No power when key is turned on
Re: No power when key is turned on
Ospho is an excellent finishing step to passivate derusted steel, and leaves the surface with a protective coating. Vinegar is actually not a great choice for derusting, leaves steel in a vulnerable condition. Phosphoric (Ospho) or Oxalic are both better choices, and reusable.
Getting more tools is never a bad thing but you don't need a brass punch to install the pressed in idle jets.
A wood dowel works fine, in fact I use a pencil. When the shoulders of the jet land you will feel it.
Bill Kemp
Post by Bill Kemp »
Ah. Great idea on the pencil. That would be great for me
Thanks. I also,have some wood dowels and will check to see what diameter is best
Bill
Editorial comment - everyone should have a set of brass punches. FWIW, I seat my pressed-in jets a lot more firmly than a pencil will stand.
Forgot to comment on the vacuum valve. Yes, it should be taken apart and inspected/cleaned. It can fill up with tarry residue also. Take good photos before disassembly - it's hard to figure out how it goes back together, and I've taken apart a bunch of them.
ICOA Rally Director
ICOA Rally Director
If you don't have a brass drift, a wood dowel will do.
Bill Kemp
Post by Bill Kemp »
Well
I got the pressed in jets out. I used a 4-40 small tap and tapped out the top of the jet 2 thread turns.
Then I used a 4-40 bolt, nut and washer to gently pull out the jet
Worked like a charm. Thanks for the tip guys.
I used a rubber fuel hose and put the jet in it along with pliers to hold it while I removed the screw. I did not want to mar up the sides of the jet.
Now I can clean the jets and tap them back in (with either a brass punch or dowel) to seat them and they will be like new again
Woo hoo
Perfect, now run your carb bodies through the ultra-sonic again as there'll be more to get clean after removing the jets. Let me know when you get the jets tapped back in and before you assemble further. There are some passages you need to be certain are open and I'll tell you how. Do you still need the one mixture screw?
Bill Kemp
Post by Bill Kemp »
I have ordered an aftermarket mixture screw but I would prefer to put an original one back in to match the other 5 mixture screws
Bill
Bill Kemp
Post by Bill Kemp »
I am heating up the ultrasonic cleaner now to put the bodies back in again.
I will also put the jets in as well now that they are out and free. I still will clean them by hand though to ensure they are pristine before re assembly
Bill
Well done, this was needed.
You want Dave's coaching. You want Dave's coaching. Did that on purpose :-).
Bill Kemp
Post by Bill Kemp »
Well. I cleaned up the jets. I took a few pictures of them. I used my pin drill bit set and cleaned out the holes by running the bit backwards so I did not take any metal off of the jet holes.
Drill bit size was #68 using the pin vice
Then I used 0000 steel wool to clean up the jets to get any grime off of them before I installed them again and gave them one last cleaning with brake cleaner on the jet and the carb before installation.
I used an aluminum spike to tap them back in place. My buddy has a milling machine and a metal lathe so we took some metal off the aluminum spike so it would fit nicely into the hole.
Thought you might want to see some photos
Bill
Bill Kemp
Post by Bill Kemp »
This is crazy here in Toronto
Just when I am trying to get ready for motorcycle season it is Snowing again
Bill
The sideways photo is appropriate for the subject.
Good that you got the jets cleaned.
Bill Kemp
Post by Bill Kemp »
:laughing-rolling:
Great job Bill.
