stock air cleaner for a 1980
- bdento59
Am I correct in saying that the 1979-80 stock air cleaner is NLA? If not, will the 1980-81 element fit? I have an '80 with a K&N and I'd like to go back to stock to help sort some continuing carb and mileage issues.
TIA
TIA
Bill Denton
Yardley, PA
wkdenton@verizon.net
Lazarus Cycleworks, LLC
Yardley, PA
- bdento59
Dave, I have a K&N using the stock spring to secure it. I've never seen the '79-80 stock setup, but it looks like a metal cage with foam over it on the microfiche. I'm just trying to get back to as close to stock as I can in an effort to minimize tuning variables. I want to see how well I can get the carbs tuned throughout the range, and once i replace the pilots, I hope to be in a better piosition to do so. That's where i'm going with the stock air cleaner setup, especially since I've heard so many folks talk about a big mid-range flat spot with the K&N that can't be tuned out.daves79x wrote:Bill:
The foam element is available, but the screen and spring (you'll need the spring with whatever you use) are not. Dave
Bill Denton
Yardley, PA
Yardley, PA
- bdento59
Darn it Terry, I was just begining to believe everything I read AND hear on the internet and you had to go and spoil it.Terry wrote:I run K&Ns on my 79 and 82 and never feel any flat mid range. I'm assuming my carbs are stock. Oh, they are 'in the airbox' filters, not pods.
Bill Denton
Yardley, PA
Yardley, PA
Sorry Bill but they work fine. The 82 has over 92,000 and the 79 is almost to 50,000. I traded the stock frame/foam cover unit on the 79 to Louis who I'm sure can find an 'OE only type' owner that wants one. The foam was detiorating but the mesh frame was still good. The K&N is just easier to clean and reoil (real filter oil) and less expensive than buying and rebuying those paper replacement filters.
- SteveG
- Mike Cecchini
Hell......the whole thing is a nightmare. 2/1/2 K&N's do the trick..... as long as you go up 4 steps on the main and shim the needle 1 mm (if you run 6/6 Pipemasters.)EMS wrote:I think the stock 79 set-up is a nightmare. The foam needs to be oiled and after a while, it wants to disintegrate. It is a mess. I prefer the metal/paper element replacement. 17210-MA2-000
- bdento59
