Any Slow jet ideas ???
Don W
Post by Don W »
My slow jets are pluged on my 80 model. I have tapped the casting just above the jet and hooked up a air line to it. I am doing one at a time while soaking the other 5 with gumout, Seafoam,WD-40 and anything else that I can think of. I have a constant air supply over night with 90 psi and it is still plugged. I have had 300psi on it for the last hour and nothing is happening.
Has anyone ever pulled the freeze plug looking thing near the mixture screw????
sr71cbx
Post by sr71cbx »
CRAZY DAVE
Slow jets
Post by CRAZY DAVE »
Don, Check this site under-Major CBX Engine Problems- April 25. I did both my bikes in 2 days with this method. If you have the carbs sitting up-side-down follow the casting down to where you can see it branch off towards the corner of the carb. This is where it usually plugs. That is the route that the fuel flows to the carb throat. It comes out on the engine side of the throttle plate thru a very tiny hole. If you take some tapered speaker wire and put about a 30 degree bend on the tip of it you can follew the passageway down to the branch off point and with some luck get the tip of it into where it makes the bend!! When it does finally flow you can fill the jet tower with fuel and it will drain in 4-5 seconds. To help it along you can taper the spray tube on a can of carb cleaner to fit into the top of the jet tower but be careful because it may spit back !! -David
Don't think of it as a motorcycle-- Think of it as a very fun 2-wheeled engine stand powered by a Japanese Slant Six !!
Marc Lamarche
plugged slow jets
Post by Marc Lamarche »
I have seen at times that the slow jets were so plugged up that I had to pull them out of the castings. I used a small and long screw and turned it in the slow jet, once a good grip was obtained I used my pliers to wedge it out. Once out, it was easier to deal with, a little bit of heat with my propane torch and it was a matter of seconds. If you can't pull them out, try using a little heat at the bottom of the slow jet to soften the crud.
I have some very nice cut away views of the entire circuit of the slow jets, if you would like to view the pictures email me and I'll be glad to send them to you and perhaps work with you on the problem your having.
Marc
#5339
81 X
SS
post pictures
Post by SS »
Please post the cut away picture in the album :idea:
thanks
SS
#5671
Someone who thinks logically provides a nice contrast to the real world.
01 XL1200C 83 CB1100F 82 CBX 80 CBX
so far!!!!!!!!!!
LamarX
Post by LamarX »
Pleasure is all mine to post these cut away pictures in the album, it was very educational and got a full understanding of operation.
I still have these carbs, if you have any request to help the CBX community with any more cut away views I'd be more than happy to do so.
Thanks, Marc
81 X
Jim-Jim
What Album?
Post by Jim-Jim »
What album and where do I find it? I looked everywhere - no album :?:
SS
LamarX Pictures
Post by SS »
Thank you, they are great :idea: :idea: :idea:
SS
#5671
so far!!!!!!!!!!
