Stuck slide
Posted: Mon Jun 16, 2008 11:54 am
Has anyone ever had a stuck slide? I have encountered this on 4 of my bikes, '79 CB750, "82 CB750 and both '79 CBX's. They all use a similar carb and in fact the carb tops and sliders are interchangeable. I just finished working the carbs on my good CBX (versus my money pit CBX) for the 3rd time because of poor performance. When I would take off from a stop it sounded like it was only firing on 4 or 5 cylinders but if I opened the throttle a little more it would smooth out. I could cruise at between 25 and 40 without incident but if I opened the throttle a little more the missing would return. If I opened the throttle full it smoothed out again so it seemed to be a particular throttle range where it occurred. I replaced the air cut-off valve and accelerator pump and cleared all ports and channels but still had the problem. Yesterday I pulled them off once again and saw that #1 slide was stuck open so I pulled all open and checked the slide operation by moving the slides in and out of each cap and only 3 were free with #1 being the worst. Upon close inspection a found a shallow dent in the cap and a rub mark inside so I swiped a cap off a set of 82 750 carbs. I put a light oil in the cap guide pipe on all carbs after first cleaning with spray carb cleaner and remounted. I checked each one to make sure they snapped back like they are supposed. I also lubed the carb to pump linkage as it wasn't moving freely. I reassembled the bike and went for a ride and it was still sputtering so I decided to take a longer ride to see if it would correct itself. After about 15 minutes and as many miles the problem stopped and the bike ran great for the rest of a 40 mile ride. I suspect that a slide had stuck again and freed itself.
Now.........after my long explanation I would ask if anyone else has experienced this and wound up checking the ignition and every other system before finally discovering they had a stuck slide(s)? I do know that owners like to polish the top caps and it is easy for them to fly out of hand while using a buffer wheel and it doesn't take much to dent or distort the circumference. I hope this post will help someone else figure out their sputtering bike.
