Alternative to Using Rubber Carb Plugs
cnshores
Post by cnshores »
I was wondering if anyone has had success using something other than the "rubber plugs" , to block off the slow jet......this is required for the 1979 carbs. I was pondering using red silicone sealer, or a nylon plug that I can get at a hardware store ..
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
Not too sure about red silcone seealer being impervious but if you try here: www.macmaster.com you will find a viton components that may do the job...Failing that, maybe an epoxy would work ?
spencer
Post by spencer »
Why would you want to use something different? The rubber plugs work.
SCH
SCH Rochester, MN
