Big Carb Problem
Big Carb Problem
I am in the last steps of my 1979 CBX and I am having Carb problems. I had the carbs cleaned and new jet kit put in but the motorcycle is running really rough and will not idle below 1500 rpm. When I was working with the carbs today the air cut off valve joint in between two of the carbs pulled out. The rubber had dry rotted and cracked appart. Does anyone have an idea on what I should do here? I there anyone out there that works on these carbs? I really don't want to break the rack myself.
Any help or guidance would be great.
Thank you.
Thank you.
Rob Billings
- Amazing Poster
Rob,
The symptoms that you describe can be caused by a variety of things.
Since the carbs were just rebuilt and if we assume that they are in good working condition.............
If they bike runs rough and won't idle below 1500, you may have fouled a plug. I would suggest pulling your plugs and looking at them. While the bike is running you can spray a mist of water on your head pipes, problems can often times be traced to a particular cylinder in this manner.
Another potential issue may be a big vacuum leak. Possibly at the carb mounting collars.
Did the bike run good before the carb work?
- Amazing Poster
How did you figure out that 1 and 3 weren't running properly?
Sometimes you can move/swap parts to help eliminate variables and narrow focus on your core issue.
1 and 3 don't share a coil but you may want to swap spark plug wires/boots and see if your problem moves. Same thing with your plugs.
Also, if you haven't already done it, it would pay to snug down your carb collar screws.
If the problem isn't traced to ignition, then you would next need to take a close look at your carbs.
Please keep us informed what you find.
- cbxtacy
With a good set of plugs in the bike, let the bike idle and check the temp of all the header pipes, if you have 1 or more cold cylinders a couple things could be wrong.
1. bad coil if the cold plugs are using the same coil.
2. clogged idle circuit or circuits, most likely the problem.
The hose that pulled off is the breather hose, 1 for each bank of 3 carbs, don't sweat it but the tees are available from Honda or CBXman.
Most likely one of the "overflow" tubes between carbs 2 and 3 or 4 and 5.
They have little "tees" on the end that crack. I have been running my 79 without them for years. I don't want to break the carbs apart. Although I faintly remember that someone (maybe Nick -cbx4evr) did install new ones by squeezing them on to the tube ends without disassembling the rack.
- Amazing Poster
That was me on the vent tubes. They can be "pushed" on with a blunt tool and some lube. I'm getting ready to do it again.EMS wrote:Most likely one of the "overflow" tubes between carbs 2 and 3 or 4 and 5.
Chris We are talking about the "tees" that go on the short brass tubes sticking out between the carbs You need to send me this instruction somehow. I would really like to try it, but I could not find the how-to anymore I thought it was in a place where I am considered a persona-non-grata and did not want to venture there.
EMS, the top hoses are vent tubes, they equalize the carbs to the outside atmosphereic pressure, the overflow tubes are on the bottom of the carbs.EMS wrote:Most likely one of the "overflow" tubes between carbs 2 and 3 or 4 and 5.
The hoses on the top tubes keep debries out.
Thanks, JB, for pointing that out. I wasn't considering that the overflow and drain tubes are the same. I was thinking low is drain, up is overflow. If I just would have remembered that the standpipe in the float bowl connects to the same outlet as the drain screw.Jeff Bennetts wrote:EMS, the top hoses are vent tubes, they equalize the carbs to the outside atmosphereic pressure, the overflow tubes are on the bottom of the carbs.
