I would like to sync my 81 carbs, but don't have a tool to reach the adjusting screws. with the aluminum air tees I have installed its even harder to get in there. What do you use to reach the lock nut and screw to sync carbs? Is the honda special tool necessary? Has anyone swapped out the nut and screw for a tension spring and screw like honda has used on other carbs? Has anyone installed permanent taps and hoses with plugs to make syncing faster? Help appreciated.
Thank you.
/r
Brad
Sync tool: what to use
- cbx6ss
