Does anyone have the instructions that come with a Dyno Jet carb kit ?? I want to determine for sure what was done to my carbs (long ago).
Anyone have Dyno Jet Instructions
I don't have a solution, but I admire your problem.
Good question, I don't know. My main point is to find out what was done to the carbs when the kit was installed to see if I can revert back to stock. Since my request, I have found the current instructions on their web site, and if I assume there is no change from 15 yrs ago when this was done, I have my answer (with the help of Mike Nixon).
The net result of this is that the Dyno Jet kits usually have a restrictor that is tapped permamently into one of the fuel passages, but this is not part of their (current) kits, stage 1 or 3. That means to return to stock, all I have to worry about is a hole in the slide that was enlarged.
