Thread Index - Carbs - START HERE
Posted: Wed Aug 16, 2023 8:23 pm
This curated list of threads might help researchers with frequently asked questions. Suggestions for additions are most welcome.
Quality carb rebuild kits - 2023: viewtopic.php?f=20&t=12472
DIY carb sync tools: viewtopic.php?f=20&t=12582
Mike Nixon's carb rebuild manual: viewtopic.php?f=20&t=12395
Use of the (controversial) Gunson ColorTune: viewtopic.php?f=20&t=10823
Pods, Stacks or stock airbox?: viewtopic.php?f=20&t=9367
Replacing the throttle pull cable in situ: viewtopic.php?f=20&t=11943
High quality carb screw kits: viewtopic.php?f=20&t=11923
Carb insulators and installation discussion: viewtopic.php?f=20&t=11823
Troubleshooting a hanging idle: viewtopic.php?f=20&t=11692
Accelerator pump adjustment: viewtopic.php?f=20&t=6821
Replacement petcock parts: viewtopic.php?f=20&t=11367
Carb troubleshooting: viewtopic.php?f=20&t=10790
Removing the vacuum "auto valve" (aka "SOS" or "Spawn of Satan" valve): viewtopic.php?f=20&t=10267
Extracting the pressed-iin pilot jets: viewtopic.php?f=20&t=5507
Repairing cracked and leaking float bowl overflow tubes: viewtopic.php?f=20&t=10145
Jetting for pod filters: viewtopic.php?f=20&t=9240
Clearing stubborn pilot jets: viewtopic.php?f=20&t=9559
Removing the anti-tamper "flags" from the mixture screws: viewtopic.php?f=20&t=9481
Carb clamp alternative: viewtopic.php?f=20&t=7495
Prolink vs Twinshock airbox and insulator differences: viewtopic.php?f=20&t=7104
