Hi there,
What is the best carb rebuild manual, I have the '82 shop manual but the sequence and detail seems a bit off?
Cheers
Gladders
What's the best carb rebuild manual
- herdygerdy
Re: What's the best carb rebuild manual
Mike Nixon's book. check out www.motorcycleproject.com, should keep you busy for quite a while...
And welcome to the club!
Agree with Tony on the Mike Nixon manual.
Have a look around on his website as well. There a couple very helpful videos.
I recently re-built my carbs for my 1979 cbx ,my first attempt was without Mikes manual & although the bike was useable I had hard starting , idling issues and low response @ lower RPM , the carbs needed to be removed & re-built , I borrowed Mike Nixons carb re-build manual from a fellow CBX'ER & it was of great help as the bike now runs like it should without any carb issues ,,I think it's money well spent if you have to purchase one , you really want to get the re-build done correctly the first time and avoid the hassle involved in removing and replacing the carbs a second time .
- bobcat
and a library of very good tech articles. At the bottom of the first seriessteve murdoch icoa #5322 wrote: ↑Wed Oct 05, 2022 8:43 pmAgree with Tony on the Mike Nixon manual.
of articles, click on "more tech articles" and there's a whole lot more.
Bob
Thanks chaps, will get one ordered
