Does anyone know if you need to seal the rubber carb insulators to the mid box when replacing them? These are the two piece, three insulators between the rear of the carbs to air box. They have a two sided channel and seem very tight but it looked like there was a sealant in the past
Carb mid-airbox rubbers
ICOA # 6786
Bike in the garage right now:
1979 CBX1000 red
1980 CBX1000 red
1981 CBX1000 prolink
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 sulfur yellow
1975 gl1000 red
1976 gl1000 sulfur yellow
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
1978 cb750f super sport
1979 cb750f super sport
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
Re: Carb mid-airbox rubbers
Honda did, probably not necessary though. I have used black silicone sealer for that as it matches what Honda used. Unless those had to come out for repair/restoration, they were not meant to regularly come apart and should not be separated normally.
They weren't even available separate from the airbox as a replacement part.
I know, it kills me when ebay sellers separate these air chambers into all the separate parts to sell.
