Gas tank replacement ???
Before I spend a bunch of time and money trying to seal up a leaking gas tank, l thought I'd ask if there is such a thing as a replacement tank for my 81 CBX ? Is there a similar tank from another bike that could be adapted ?? Any other options such as a fiberglass tank? Thanks for any leads. Dave
Re: Gas tank replacement ???
harvey
Ride Safe and Ride Often
You could probably "adapt" a fuel tank from a 1979/80 CBX and the 82 tank will fit perfectly. Anything else will be a tall order, due to the wide frame section of the CBX.
Stay away from fiberglass tanks. They do not work well with ethanol gas.
81 tanks are available, due to the fact that many "school bikes" were parted out.
Tanks Harvey,sent them an email. Daveharvey wrote:You might try Louis at http://www.usedcbxparts.com.
He normally has a few good replacements in stock.
Another person to check with is Tevan.
He MIGHT have what you need.
I have had excellent dealings with him.
memberlist.php?mode=viewprofile&u=8317
- wyly
Tims CBX has tanks , I believe they want an exchange with your tank..
Six Center Motoren has tanks as well...
and then there's ebay, tanks come up quite often...
and, Louis at usedcbxparts.comwyly wrote:Tims CBX has tanks , I believe they want an exchange with your tank..
