Issue between 2500 to 3000 rpm
Re: Issue between 2500 to 3000 rpm
I am through half bottle of sea foam so far has done no improvements. For me, pipes did not make any difference to the issue I am facing. Hesitant to remove carbs especially not knowing what I will be looking to fix. Bike otherwise runs great, idles all day, charges battery at idle etc etc
1979 CBX (faster Red)
1981 CBX Streetfighter
2017 Aprilia Tuono.
2017 Aprilia Tuono.
- cross
itsacbx wrote:Im in Canada, eh and I have an identical problem on my 79......sorta......
My bike has a K & N and Kerkers and I had the carbs off 4X, yes you read that right....FOUR freaking times.
There was an upside - I can now do a carb removal in 20 minutes tops!!!!!
My initial problem was created by giving the carbs to my local Vintage Club guy who had just acquired a soda blaster - well f#@* me it took me a week to get what I thought was all the soda residue out of the carbs, add my Randakks bits and pieces and shove her all back together.
Bike started perfectly but then ran on 1 or 4 or 2 or 6 cylinders .
Long story short it now idels perfectly and runs unbelievably well except for the burble/miss/stutter at a point where I believe the pilot jet doesnt function anymore as it transitions to the main jet.
Im also starting to think it may have some megaphonitis from the Kerkers.
I also see there is some issues about the K & N.
Lucky me I have a set of stock pipes and a stock filter, so once the damn rain stops Ill try those before I take the carbs off again.
Al
Take that K&N and throw it away as far as possible and use stock paper filter
Sasha
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
