Phil: I don't know why you feel offended and why this has to turn into a p...ng contest. All I am saying is, that the real remedy was the vacuum valve and not the change to the later overflow line configuration. If you take a vacuum valve out of a later model bike and leave the lines unchanged you still risk hydrolock. Carbs 1-3 and 4-6 are still connected. 10-7.FalldownPhil wrote:If you're happy, I'm happy
Carb overflow lines
Re: Carb overflow lines
Wow at all the replies. Thanks!
So to recap, with the setup I have (79 carb set on an 80 CBX) if I avoid using the sidestand ( I don't particularly trust it) and always turn off the petcock after shutting down, I should be ok leaving these drain lines hooked up?
Never a problem with my 82 which I run sans vacuum valve. Just always turn off the fuel. System has automatic reminder feature if I (you) forget to turn it on.
- FalldownPhil
Mike, I am not feeling offended at all. We have been friends for way too long for me to be offended.EMS wrote:Phil: I don't know why you feel offended and why this has to turn into a p...ng contest. All I am saying is, that the real remedy was the vacuum valve and not the change to the later overflow line configuration. If you take a vacuum valve out of a later model bike and leave the lines unchanged you still risk hydrolock. Carbs 1-3 and 4-6 are still connected. 10-7.FalldownPhil wrote:If you're happy, I'm happy
We both have opinions to which we are entitled unless something has happened to our 1st amendment
Very Best,
- FalldownPhil
Yes !!Playtex11 wrote:Wow at all the replies. Thanks!
