Generator thrust washer
JeffreyD
Post by JeffreyD »
Can anyone tell me the suggested thickness of the thrust washer behind the generator clutch?
Dave Ditner
Alternator washer thickness
Post by Dave Ditner »
You're in the wrong area. Answers to your question is in the electrical section under alternator., but here are the numbers anyway. The plastic washer is 2 mm thick, the metal washer is 1/5 mm thinck and the spring free length is about 29.5mm :cheers: :cheers: :cheers: :cheers:
Davey
