Replacing Vent Tubes
I will be repainting some parts from my bike this weekend and in order to do so this I obviously had to remove them. This included the air box which I found to be a pretty complex process. In end I noticed the two vent tubes that lie between the 2nd/3rd and 4th/5th carbs were dry rotted. I then removed them and found this was the beginning of my trouble. Does anyone know of a way to replace them without separating the carbs...? And how important are these vent tubes in function? Can I get away without installing something exactly the same as the original?
- alimey4u2
- ICOA Web Video Director
The vent tubes are there to ensure that atmospheric pressure is equalised in the float bowls. They are high to prevent the ingress of water/ contaminants into the float bowls. Any Nitrile rubber tube of correct size will work. I have read of replacing the tee's without carb separation, Randaak or Mike Nixon ( plus some other guys) may advise....
You can replace the vent Ts with original Honda ones without separating the carbs. IF they are still available - not sure on that, but if they are they will set you back about $60. You cannot replace them with the aftermarket ones available (TIMS, Randakk) without separating the carbs, as far as I know. About the same price.
You really don't need any vent tube - you can just leave them off. Many guys on here don't run them at all.
Somebody, a while ago, somewhere had a picture story about replacing the tees without splitting the carbs. I remember it involved wooden sticks from ice cream bars I tried it on a set of carbs that were off the bike and I found it at least as difficult as removing the airbox without tilting the engine. I run both CBXes, and will run a third one, without them
- Randakk
My reproductions can be installed without splitting the carbs. Not the easiest task...but it can be done. Mine are very faithful to the OEM geometry.daves79x wrote:You can replace the vent Ts with original Honda ones without separating the carbs. IF they are still available - not sure on that, but if they are they will set you back about $60. You cannot replace them with the aftermarket ones available (TIMS, Randakk) without separating the carbs, as far as I know. About the same price.
Randall Washington (Randakk)
Founder & Chief Executive Rider
Randakk's Cycle Shakk, LLC
Pinehurst, NC USA
www.randakks.com
Pinehurst, NC USA
www.randakks.com
