How To Add An Avatar
Posted: Sat Jun 26, 2010 9:43 am
Because of a recent question from a member, here is a description on "how to" for all. The "Avatar" is the samll picture, that appears in your identity field when you make a post:
To place a picture (Avatar) in your ID field, you have to manage your profile.
Click on “User Control Panel” on the left side under “ Board Index” after you log in.
The panel comes up and you select the tab “Profile”
In the profile, there are “edit” selection tabs on the left. Select "edit avatar."
There you can upload a picture, but watch for the size restrictions. I recommend you prepare the picture BEFORE you edit your profile. The size is limited to 150x150 pixels and 48 KB.
