Hi All,
Just thought I would share a couple of photos of the Fuel Injection system that I am build for my 1425cc CBX Cafe Racer as un upgrade for the CR Smoothbores currently on the bike.
The core of the system is now complete , but still need to mount them up in 2 x banks of 3 Throttle Bodies then set them at the 20 odd deg V angle. Also still need to machine up the fuel rail and few other bits and pieces.
Starting to look nice and as it is in the photos they only weigh 700gms and with everything fitted including injectors, fuel rail, fuel reg might only weigh in at a total of about 1.5kg , way less than a std set of carbs.
Going to be fitting to this bike;
Cheers
John
Taimoshan Cycle Works
CBX - Carbon Fibre Fuel Injection Project
Re: CBX - Carbon Fibre Fuel Injection Project
Really nice looking set-up, John. Have you figured out how to address the fuel injection control and mapping? What controller will you be using?
I have a number of years experience with MIcrosquirt units on bikes and have the latest Microsquirt V3 unit to install, but I am only going to run fuel mapping from the ECU, batch fire triggered from the coils. I will be leaving the PowerArc triple spark ignition in place for the time being as it will save time and re-wiring and there is a definite power benefit to the triple spark system over the single spark option from the Mircosquirt.
- Syscrush
Wonderful.
EFI is a longer-term goal for my bike. I'm watching this with great interest. I heard that MS V3 is a pretty radical little controller.
Will you be running it closed loop or open? I would really love to get a closed loop setup with a catalytic converter working, but that might be too ambitious.
Any chance of an update to this and some pics of the injection system?
