Jon's cbx
Jon's cbx
Hello here is my project 82 cbx.
Its in good condition but hasent run since 2005.
Have clean the carburators and got it started thats it.
Re: Jon's cbx
Removed some parts.
Next up is to remove swingarm and replace it with a dual shocks swing.You do not have the required permissions to view the files attached to this post.
Re: Jon's cbx
Have drill out the old upper bolts and replaced them with longer to fit shocks.
Now waiting for new swingarm.
Re: Jon's cbx
So the new swingarm came today, but was not as expected. Think i got the wrong cb swing.
I can shorten it but looking for a more bolton.
Re: Jon's cbx
…a now the adventure begins.
Can I ask why you’re ditching the monoshock and the rising-rate linkage? The Prolink setup with the stock monoshock offers ~4 inches of rear wheel travel in a rising rate setup, When paired with a decent aftermarket shock like a Progressive/Ikon/YSS/Wilbers, it’s quite good - compliant and comfy over little stuff, very controlled and well damped over bigger stuff. Most any twin-shock setup you graft onto it is going to result in less rear suspension travel.
Is this mostly a style consideration? That’s reason enough, I’m certainly not faulting you for that, but it cant be performance-related, in my opinion.
Re: Jon's cbx
Totally agree with Nils. However, if you must have twin shocks, you have the best swingarm you could possible get already there. Just weld on a set of shock eyes. You can also machine off the Pro-Link linkage mounts for using a wider rear tire.
- bikeymikey748
Re: Jon's cbx
Jon, impressed with the excellent condition of your bike. I mean, look at that exhaust!
Jeg må berømme deg for engelsken din, den er utmerket.
Best of luck with your mods.
I think you might find that any swing arm of more recent manufacture will the reflect the trend that factories took of increased length.
Re: Jon's cbx
Exhaust is aftermarket. I wasnt any good at school so my english still sucks
- aahrens1
Re: Jon's cbx
Hi Jon
Check the Yamaha XJR 1300 swingarm for your project. I had no big issues with it.
Best design has the latest model RP19
https://photos.app.goo.gl/RzRxt2dUvP42Nsdx6
https://photos.app.goo.gl/KBat3UT6WqED62hi9
Regards
Andreas
Andreas
Re: Jon's cbx
I have one of these left, a braced ZRX modified to fit he CBX.
Re: Jon's cbx
Again - what do you think is wrong with the stock swingarm?
Re: Jon's cbx
Nothing wrong with them they are sturdy but heavy as hell, a lot of unsprung weight going on there, most modern swingarms are aluminum for a reason and have better axle adjusters and adjustment, like the eccentrics on the ZRX I posted.
If none of that is a concern I’d do what Dave suggested, it’s a proven and easy modification.
Re: Jon's cbx
Jeff - he already has an aluminum swingarm - it's a Pro-Link. Nothing better than that to weld shock eyes onto and it already bolts on.
Re: Jon's cbx
Yes but like I mentioned, most the modern swingarms have eccentric adjusters, makes it a breeze to drop your rear wheel, and the eccentrics allow up and down and back and forth adjustments.
