Bikini Fairing fabrication
Posted: Fri Nov 06, 2020 3:04 am
I find it annoying when I paint my bikes and then invariably they get scratched at some point. Every time I climb on I'd see those scratches. Scratches combined with broken pegs on plastic panels, there had to be a better way. Then I came across some vintage bikes on Instagram with bare aluminum fairings and bodywork, no paint, scratches can be buffed out and panels can secured with bolts/pins/fasteners.
I asked a friend who was an aviation metal fabricator how difficult it was, "There's a learning curve but you can do it. And I have an English Wheel and sheet metal Brake I can lend you." I had no idea what I was getting my self into .
I'm halfway through my fabrication of my new body work for my GSX and about to begin on the fairing which is a major challenge so I thought I better get some practise on something smaller, replacing the acrylic bikini fairing on the CBX. Using the old fairing as a template I drew out what I wanted on some scrap from my GSX project. I wanted to completely wrap around the headlight but if I failed I was prepared to cut it back to match the template. I'm also considering swapping the CBX headlight for a 8" GSX headlight so the opening would need to fit both sizes.
https://www.cbxclub.com/forum/download/ ... 632df247a6
