CBX 82 project
- aahrens1
Re: CBX 82 project
Voltage, oil-, water- and air temperature, oil pressure, travel time, max speed/rev, average speed, max acceleration/deceleration, actual accelleration, gear number, 0-100km/h timing
unfortunatly no actual time :-(
Regards
Andreas
Andreas
Re: CBX 82 project
Woow i like it! Cant wait to start with it. Where did you get your upper triple? I guess mine is waiting when I get back from work. Ordered from topyoke. Can I ask where you got the instrument holder? I need one. Like how yours is mounted.
- aahrens1
Re: CBX 82 project
You can not buy it, do it yourself.
You need an aluminum sheet metal of 4mm thickness
Regards
Andreas
Andreas
- Syscrush
Re: CBX 82 project
That's a very nice cockpit.
- wyly
Re: CBX 82 project
[/quote]
[/quote]even more than that, you can adjust your indicator flash speed(brake light as well I think), remote and key-less start, security system, "find my bike if stolen", Munit-blue has gps mapping to your phone. There's probably even more, that's I can recall. An amazing bit of kit.
Re: CBX 82 project
I like it, nice custom work
How do you wire and make that gear number indicator to work?
Interesting to see where you put the oiltemp sensor and speed sensor.
Theggi, hopefully it's ok for you that we post on your thread
- aahrens1
Re: CBX 82 project
You have to make a calibration run. The instruments calculate the gear number by engine/wheel speed.
Speed signal comes from the rear ABS trigger ring and the oil temperatur sensor sits in one of the oil plugs.
@Theggi: my CBX project is also a 1982
startet in 2020
startet in 2020
Regards
Andreas
Andreas
- aahrens1
Re: CBX 82 project
Try to get it street legal within the next weeks...
Regards
Andreas
Andreas
Re: CBX 82 project
Looks more street legal than original
1979 CBX (faster Red)
1981 CBX Streetfighter
2017 Aprilia Tuono.
2017 Aprilia Tuono.
Re: CBX 82 project
Its very ok
Re: CBX 82 project
My carbs are going for a makeover. Previous owner have painted them and they dont look good. Sprayed over every bolt, spring etc. Now i will waterjet them and put a keyster rebuild kit in all of them. I found these two air tree fittings that were broken. Looks like he tried to fix them before with silicone or something. Does anyone know where i can get this rubber? I Just find it with the tube for around 50dollar each.
Re: CBX 82 project
DO NOT use Keyster rebuild kits. Re-use all of your original brass, get new Keihin float valves if needed and all Viton rubber parts. Cary Knapton at the Supersport Shed in the UK has all the correct parts, including the vent T rubbers. He is likely the closest supplier to you, others may chime in.
Re: CBX 82 project
Oh? Thought I read somewhere else here keyster was recommended. Why not? Thanks for the tip, i will contact him.daves79x wrote: βSat Oct 01, 2022 7:13 amDO NOT use Keyster rebuild kits. Re-use all of your original brass, get new Keihin float valves if needed and all Viton rubber parts. Cary Knapton at the Supersport Shed in the UK has all the correct parts, including the vent T rubbers. He is likely the closest supplier to you, others may chime in.
