Nils,as always, thanks for the input. I'll see about e-mailing Preston in a bit. For now, knowing how many degrees full advance is....my buddy,John, loaned me his adjustable Snap-On timing light.It's as easy as slapping on the clear cover, and dialing in the specs for idle & full advance to verify. Sometimes, the answer is right in front of your face.
Dave, timely input, again. I was thinking the same thing,regarding the 'kit' needles and why the Dynojet mains are actually smaller than the stock 105's. I gotta figure that they,Dynojet, know their stuff (hey, I bought their kit,right?). I don't know that I'll try 120's initially, maybe 115's, taking into account the new needles' ability to pass more fuel.
I ruled out the possibility of a defective air-cut valve affecting off-idle fueling by plugging the buggar ( as per recommendations on the board).
I have a better selection of mains, 110-125,inbound.I realize they have little to do with my idle/fueling issues, they just popped out at me when I was looking into the carbs after the initial,poor, start-up.
I guess that the carbs are
very sensitive regarding balancing. My initial set-up was less than ideal. I went back and synch'd them manually (using surgical wire under the throttle plates),they are now
much more equal as regards initial settings. Also,I had previously adjusted my ,Suzuki, balance tool by plugging the common fitting for the four gauges to an EVAP vacume port on my CAMRY
I now realize that's likely why they wouldn't register properly,much different properties between the Camry and the 'X'. I'll be using the vacume from the CBX to set them up next time with, hopefully, better results.The only other possibility for the tool's poor performance would be lack of vacume being produced on the Honda (valves,cam timing,leaks). I'll do a quick leak-down test later this week too.
I visually inspected my idle jets,after cleaning, clear. I also blew compressed air into the jet passages and verified that it passed through the mixture screws and into the orifices on the carb floor.All good.
I'll,recheck, my base timing too.
So, its a waiting game for parts, most likely by week's end, before my second kick at the can.
Meanwhile its back to, a bit more, wiring.
I'm trying to get it together for Americade......TIC.....TOK !!
Plug leads seem ok, as per manual.
Mixture screws are now set at 3 turns out , I had them at 2 1/2 previously.
Needles/clip position are as per the Dynojet instructions.
