I hear you loud and clear. Very particular, these carbs. Will this kit be all I need if the boots are OK:cross wrote:About the high idle,
There could be few reasons, vacuum leak, sticking cables,not properly adjusted floats, sticking slides etc.
I found few holes in my airbox boots when I took the carbs off which apparently came from previous carb cleaning.
Previous owner had told me that the mechanic who cleaned carbs could never get bike running right and most likely this was the cause.
I patched all holes using inner tube repair kit.
Every symptom that you are having points to your carbs, clean them!
http://www.ebay.com/itm/131106008055?ss ... 1423.l2649
