Fuel feed between 5 and 6 carb.
Would it be best to have the fuel feed between the 5 and 6 carb? Rather than between the 1 and 2 carb.As then you can put a decent length fuel pipe with a bigger filter.What are your thoughts?
Re: Fuel feed between 5 and 6 carb.
It would work just fine, if you're going to separate the carbs anyway.
Yes i have separated the carbs as put in new o rings etc.It is so much better to be able to put in a decent fuel filter with the longer fuel pipe.daves79x wrote:It would work just fine, if you're going to separate the carbs anyway.
