I will be picking up a 80 CBX soon to start restoring and I am a big fan of home powdercoating. Has anyone here powdercoated their master cylinders and calipers before? I want to make sure I will be able to tear everything down far enough to put in the oven and bake with out distorting or melting anything. Plus any tips related will be greatly appreciated.
I have powder coated brake calipers on my own bikes and I am still doing this a lot for friends. Works fine. You usually don't set the oven hot enough to distort anything. Proper plugging of the holes when spraying is really important. Also cover the flat surfaces around the brake line connections to make sure the seals sit right afterwards.
EMS wrote:I have powder coated brake calipers on my own bikes and I am still doing this a lot for friends. Works fine. You usually don't set the oven hot enough to distort anything. Proper plugging of the holes when spraying is really important. Also cover the flat surfaces around the brake line connections to make sure the seals sit right afterwards.
Thanks for the quick reply. I'm assuming the front and back master cylinders are good to powdercoat too. Also, what about the lower fork legs? I noticed in a resto article the person decided to paint instead of powdercoat. Any issues with those parts?
Powdercoat for durablity, stove enameling for finish....
As Mike has said int he prior post, just make sure that the engineered mating sufaces are protected in the spraying process. As all components are uniformally heated, distortion becomes negligible...
As was said above, preperation is the key. I even powdered in the red dots on all of mine, what are those for anyway ?, masked them off and overpowdered with black.
