Help removing a ProSus rear on an 82 please
Any help around here? Took a look at the bike and the manual so does the shock lift out or drop down once its unbolted? Do I need to remove the battery and battery box and/or the rear wheel and/or the front inner fender? Not having done this before, it (appears) that the shock bolts loosen from the sides under where the side covers fit and it also (appears) that removing the wheel isn't necessary. Am I right? It sure is a PITA working so close with my bifocals...damned old age!!!
