30 amp fuse
tazz
30 amp fuse
Post by tazz »
Hi guys I was going through the bike and and I decided the check the Dog fuse glad I did I had no spare(backup one). So off to the Auto part stores :evil: when to 5 diff. auto part stores and no one had the 30amp flat blade type fuse. So I had to order it for Honda #98200-53000. Question do any of you know if any auto part stores have is type of fuse. Also there is or they have a fuse pocket the you can but any size of fuse you need and it has a wire at each end has any of you used this in place of the flat blade fuse.
Re: 30 amp fuse
Those are proprietary Honda fuses and every owner should have a couple of spares. My local dealer stocks them. That said, many guys cut out the fuse holder and install a modern blade type fuse holder. I like to keep mine stock, but that's your choice.
