Thanks again Dave - that addresses my main concern about the CB1100F swingarm. I'm still leaning towards the Trac one, but nothing's carved in stone at this point.daves79x wrote:Shock mounts on the F swingarm are exactly the same distance from the pivot as the stock arm. If you try to raise the rear with longer shocks, keep in mind that the front with the forks you've considered will never come close to matching the rear rise. I personally wouldn't try to totally reinvent the wheel on this.
I just did a quick calc of the amount the bike has been lowered as a result of the swap to CB1100F wheels. My source of data is the recommended tire sizes for both bikes on the Avon website. Based on that, it looks like the front has been lowered 12-13mm and the rear by only 3-5mm.
If that's correct then if I can get the bike ~15mm higher than it sits now, it'll be back to very close to the stock height in front, a bit higher than stock in the back. Given how conservatively I ride on the street, I think I'd have plenty of clearance for 25mm lower pegs.
I could get that 15mm at the front if I stick with the OEM forks and drop them in the triples when I switch to handlebars, since I would no longer need so much fork protruding through the top triple once I don't have clip-ons mounted to them above the triple.
Even so, I'm planning to go visit a shop that has a Duke 690 on the floor now so I can take some measurements of the forks. If they really are within 2" of the length of the stock CBX forks, then a top triple with a drop in the fork clamps might get me there. It would be a lot of money & effort for no meaningful performance increase, but it would be pretty rad if it all works out OK.
One big concern that I had about going to USD forks is mounting the CBX fender in a way that doesn't look horrible. This morning I studied a bunch of pictures of the Ducati Sport Classic front fender mount (the one with the metal mounting bracket), and then my CBX fender, and I realized that the CBX fender actually has steel tabs between the ABS fender and the mounting points on the fork - that should make it easier for a decent welder/fabricator to fashion a workable mount that looks something like the Ducati one:
![Image](http://www.blogcdn.com/www.autoblog.com/media/2009/10/ducati-sport-1000-large_10_opt.jpg)
