1979 CYLINDERS ON 1982 ENGINE
sostaats
Post by sostaats »
What do I need to do to use a set of early model cylinders on a 1982 engine. I vaguely remember that some of the holes needed to be drilled out but it was about 20 years ago when I last gave this any thought. Now I've got a 82 smoker that I need to rebuild and parts for a early model. Thanks for any advise.
CBX-tras
Re: 1979 CYLINDERS ON 1982 ENGINE
Post by CBX-tras »
Yes, just enlarge the 4 holes in the center and the 2 on either end where the smaller studs are, on the early motor.
ICOA Rally Director
ICOA Rally Director
Howdy Steve! Where ya been? It's been too long since we got together.
JR - isn't it just the four center studs? The outside two on each side are the same small ones, according to my memory and the parts book.
CBX-tras
Post by CBX-tras »
daves79x wrote:
Sun Feb 14, 2021 6:54 am
Yes, I stand corrected. Working from memory without the parts in front of me.
sostaats
Post by sostaats »
Rick Pope wrote:
Sat Feb 13, 2021 9:58 pm
Retired and moved from MN to AZ built myself a three car garage, all is good
sostaats
Post by sostaats »
CBX-tras wrote:
Sat Feb 13, 2021 8:13 am
Enlarged the 4 center holes and it went right together. Thanks.
