Pulse coil question
motorex
Pulse coil question
Post by motorex »
can a pulse coil assembly from an 81' be retrofitted to a 1980 model?
tevan
Re: Pulse coil question
Post by tevan »
I am sure it would work but you would have to change out the plug connector.
Is there another name for this part?
I am not familiar with pulse coil assembly?
herdygerdy
Post by herdygerdy »
More info' needed on this issue.
If you mean you want to replace one of the 3x pulser units bolted to a common plate that sits in front of the auto-advance & retard unit and it mounted under the small cover at 2 o'clock on the clutch cover then it may be possible.
But the '81 has (IIRC) 1/8" connectors on the wiring vs 1/4" on the '80 model.
If that is the case then I do have some information that could help to fit it into the correct position on the 6 pin connector on the '80.
PM me and I'd be happy to help.
If it is not that unit, then we need more info' pls. Pics would help too.
Cheers..Tony
I think 'pulse coil' is a perfectly adequate description of the part in question. That's what I've always called them. FWIW, Honda calls it the 'Pulse Generator'.
Once again, i stand corrected.
