Spark units
Spark units
Here are my spark unit, read somewhere that this might not be a sign of failure or degradation, any thoughts?
Also on the same subject, if I were to replace it, which aftermarket will you recommend, i found so far:
1. Ricks
2. Pazon
3. Marktronics
Any pros and cons on those units?
Cheers
1. Ricks
2. Pazon
3. Marktronics
Cheers
Re: Spark units
They may still work with the black goo melting out of the units.
'81/'82 Pro-Link spark units will work and won't make a mess.
If you wanting to buy aftermarket i would get an aftermarket ignition system instead and eliminate the spark units.
C5 and Dyna make systems for our bikes.
Re: Spark units
C5 a bit expensive. However, they do look modern tech. Disclaimer: Have not used them personally.
Re: Spark units
Thanks guys
The C5 is the only one available, the Dyna is no longer offered.....
I guess not much of a choice
cheers
cheers
Re: Spark units
Here is what I found:
- C5 Ignition:
JH-1006 6 CYL CBX1000 - REPLACES SPARK BOXES AND ALL HONDA IGNITION PARTS. THIS IS A COMPLETELY NEW IGNITION KIT. Ignition kit, MC-2 high voltage coils, and spark plug leads. Pretty much Complete : $729.00
http://www.c5ignitions.com/motorcycle-ignitions.html
http://www.c5ignitions.com/uploads/1/5/ ... _coils.pdf
- Dyna:
Its only offered by Tim Intl - comes in pieces, for comparison reasons:
SPK118 - DYNA S IGNITION, '79 - '82 INCL. INSTRUCTIONS--ELIMINATES THE SPARK UNITS WHICH ARE STARTING TO GO BAD ON ALL CBXS - $289
SPK119 - DYNA S IGNITION COILS, 3 OHM, '79 - '82 SET OF 3 - $239
SPK121 - Dyna 8 mm Spark Plug Wires - $70
Total $598 - not quite sure its all thats required to be similar to the C5 unit.
http://www.timscbx.com/Eng%20page%207.html
http://www.timscbx.com/PDF%20docs/DynaI ... nStock.pdf
http://www.timscbx.com/PDF%20docs/DynaInstallation.pdf
- C5 Ignition:
- Dyna:
Re: Spark units
I think new replacement units might be available from Pazon. Check their website. Also, consider finding some units from the 81/82 prolink. These can work with some wiring revision. Here's a good reference for that wiring: viewtopic.php?f=21&t=7473 This might be the least expensive option. Although, possibly a bit more 'modification'.
Re: Spark units
Larry, thanks you very much, decided to go with a full new version. will explain in detail some time later....
Re: Spark units
Good, Samuk. Just wanted to be certain you had as many options as we all could show you. Have fun with your CBX.
Re: Spark units
I realize this is an old thread but I would like to know the typical symptoms of a bad spark unit and a way to test them if possible.
Re: Spark units
In the hot weather, mine started to break down, so junked compete system, have got Dyna now, brilliant, tried C5 but did not work for me !Jmichaelb wrote:I realize this is an old thread but I would like to know the typical symptoms of a bad spark unit and a way to test them if possible.
Re: Spark units
A bad spark unit could act along the lines of a bad coil or cracked plug cap, a poor spark leading to poor performance.Jmichaelb wrote:I realize this is an old thread but I would like to know the typical symptoms of a bad spark unit and a way to test them if possible.
A search turns up people asking about ignition timing, low rpm carb problems, all things that could behave similar to a spark unit going south.
Some reading from Mr. Nixon about CBX electrics might help. https://www.motorcycleproject.com/text/trilogy02.html
Re: Spark units
Thanks. I will check it out. After a long run at about 90 it came down acting like it dropped a cylinder. Plugs all show a nice golden brown burn. My gut tells me electrical.
Re: Spark units
The bike will drop 2 cylinders when a unit goes bad. Easy to feel and diagnose, just see which 2 pipes are cooler. Usually 2/5 unit goes first. Many will run fine until good and warm, then cut out 2 cylinders.
Re: Spark units
Is it worth the trouble of replacing the bad one only or should I replace all three?
Re: Spark units
If you want to go to the trouble of digging the bad one out and splicing a new one in, guys have done that. A lot of trouble and you have to identify for sure which one it is. I’d spring for a whole new aftermarket unit.
