- cross
New addition to my stable is an '03 Valkyrie. Got it in non running condition do to sitting for very long time.
Got the carbs apart for cleaning and rebuild as they are leaking and throttle wasn't moving more than 1/4. Found that carb #2 shaft is stuck so i cleaned it and now it's fine.
Had to order all O rings, gaskets and float valves since about half were not closing and fuel was leaking into the carb bodies.
Need to test aircut valves before i put things back on the bike, replace timing belts, check valves and do all fluid change
Anyone here with knowledge on Valkyrie?
Sasha
Sasha
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
- FalldownPhil
Sasha,
Do you know George Dillaway? He lives in Chula Vista. George has a Valkyrie sidecar rig.
Best,
Phil
Best,
Phil
- cross
Yes, i met George once few years ago
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
- wyly
we've had a warm winter out west as well with temps up to 10c there are a number of riders still out there everyday...I was really tempted to join in so I climbed on the GS see if my new knee would flex enough to ride it was a no go ... I'm sure my surgeon wouldn't approve
- Syscrush
I looked at mine longingly and wished I could ride it. :)
- Syscrush
I finally rode it again - HOORAY!Syscrush wrote:I looked at mine longingly and wished I could ride it. :)
Into storage - BOO.
- Limey01
Reassembled the rear end with new tire, rebuilt master cylinder, brake caliper and new brake pads. Now pulled the front end apart, brake cylinders disassembled, one caliper rebuilt. Tomorrow is rebuild the other caliper and master cylinder then fork seals. Get to spoon on a new front tire too. Lot of cleaning required but at least it all seems serviceable.
Better to remain silent and be thought a fool than to speak out and remove all doubt.
- Limey01
Okay so the brakes are all done, although the front calipers aren’t back on the bike yet, fork seals are in and forks back on the bike (that snap ring is a bitch, stronger than my snap ring pliers), still have to fill with oil and reinstall the springs. Front tire is on but I am now fighting the front axle nut. Need to pull the axle to get the wheel on my truing stand to balance it. Applied enough force to splay a SnapOn 17mm wrench on the opposite end and it didn’t budge. Currently sitting over night with some PB Blaster applied. I don’t have a deep well socket that will fit over the axle to use an impact on it but I’m thinking that’s what it is going to take. Maybe a trip to Home Depot tomorrow to buy a sacrificial socket and bore it out to fit over the axle.
- desertrefugee
Sat in the garage late into the night last night mostly looking at the custom '79 I picked up yesterday. But, I also did a fair amount of detailing. It was pretty dusty (been laid up for 10 years). Caressing all the nooks and crannies is a great way to bond with a new machine. Found a few warts, but I'll chalk that up to 40 years of hard love. I'm not a fan of the patterns the PO put in these rotors...
Finally, weather warn enough to open garage door and work on bike.
Pulled the carbs, removed the K&N pods, installed an original filter box and plenum, re jetted carbs to stock jets. Big thanks to Mike Nixon for giving me the option of Hex head screws when he cleaned and rebuilt the carbs a few years back. Now I get to have the joy of fitting the carbs back into place.
- wyly
instead of fitting the carbs to the engine fit the engine to the carbs... grease the rubber and carbs and let them hang by the controls supporting them with one hand then lift/jack the engine back into position and slowly press back into the carbs, checking alignment as you go... easy peasyMouse wrote:Finally, weather warn enough to open garage door and work on bike.
- desertrefugee
Kinda makes me want to go out and source an OEM airbox...for when I get the joy of pulling carbs again. Not soon, the last carb job is still too fresh in my mind!
...and in keeping with the thread topic, finished getting the swingarm back in with brass bushings. Re-installing the shocks, I found that the PO had installed hard plastic bushing in the upper shock mounts. They crumbled to dust when re-inserting. Well, that's a snag - until I remembered my bushing stash. Found some unused rubber ones that needed the center reamed out a bit and on they went - unsleeved. I'll get some proper ones "soon". Didn't want to be dead in the water for want of those danged things.
- wyly
spent 4 hours over the last two days trying to fire up the GS , fresh gas in tank, spark good, the occasional pop and backfire but nada...after trying starter fluid and not getting a response I figured the gas wasn't getting through ...35year old vacuum line from the carbs to the gas tank was looking a little old and stiff (like me)maybe it was sucking air, so I switched it out to fresh line and it fired right up
Well. Got the carbs in and hooked up the Wyle way and ........wait for it.....
Today I get to undo my weekends work because I hooked up the thottle cables backwards.
stupid mouse
stupid mouse
