Advice on purchase
Re: Advice on purchase
Postby nzfrank » Fri Jan 19, 2018 11:27 pm
Here is a picture of the tool kit that I believe is original.
nzfrank
Postby Dynamohum » Sat Jan 20, 2018 5:48 am
Have you had an old bike before?
Dynamohum
Postby daves79x » Sat Jan 20, 2018 7:19 am
The tool kit looks great - original bag even looks pretty good. The original wiring looks great, except is that a replacement main fuse holder? You even have the original '8-track tape' battery spacer!
Images: 0
Postby Larry Zimmer » Sat Jan 20, 2018 12:42 pm
Great 'buy', Frank! From this thread, and just generally speaking, I'm certain you have received all manner of 'advice'. So, my contribution: Check all the wiring harness connectors for corrosion. Especiall, check the connector on the right side which is associated with the battery charging circuit. Any corrosion in that connector will cause sufficient heat to damage the connector with time. Besides, causing battery charging issues. Then, all the 'usual' things such as brake system flush, being certain the pistons are free and no corrosion. Might be worth a rebuild -- installing new seals in the calipers. Not all that difficult a task.
Above all -- enjoy :D :D
Images: 198
Postby nzfrank » Sat Jan 20, 2018 5:22 pm
Hi
Many thanks. I have had several 1970s bikes, but they were all owned in the 1970s and 1980s.
The seller advised me of the non genuine fuse holder. I will try to find a genuine item.
The brakes have been overhauled with new pistons (honda genuine), seals and lines.
The carbs have been overhauled and she starts first push from cold or hot and runs sweetly.
Valve clearances have been set as part of a service a few Km ago.
It also came with a spare tank and tail piece that a previous owner used to fit to go touring (that may account for the state of the red paintwork).
nzfrank
Postby daves79x » Sat Jan 20, 2018 5:43 pm
Your stock strip fuse holder is still there - look like it was just bypassed with a modern one. Check out what is left of your stock one before you decide you need anything. The stock ones have proven very reliable for me, but others have had issues, my guess due to neglect and corrosion.
Images: 0
Postby Jeff Bennetts » Sun Jan 21, 2018 12:23 pm
daves79x wrote:Your stock strip fuse holder is still there - look like it was just bypassed with a modern one. Check out what is left of your stock one before you decide you need anything. The stock ones have proven very reliable for me, but others have had issues, my guess due to neglect and corrosion.
The main advantage to the updated main fuse holder is that they use modern spade fuses, available anywhere, even your corner drug store, the OEM flat fuses are Honda only and are cute and all but sometimes you just have to go outside the Honda box.
Images: 83
Postby Ringnalda » Sat Mar 24, 2018 11:50 am
:text-welcomewave: Enjoy your purchase, remember to always switch your fuel tap off when the bike is not running, please also note there are copies of the manuals already put up on this website, so feel free to browse around the technical sections. If you could write a small article with some pictures of how you found the CBX and what the history is, we are always looking for articles for the CBXPress, the publication of the ICOA. You can send any articles and high-res photo's direct to me at mrcbx@att.net.
Enjoy your great find!
Good judgement comes from experience. Experience comes from bad judgement.
Ringnalda
ICOA Staff
ICOA Staff
Images: 30
Previous
Return to Daily Discussion: By, For & About CBXers
Who is online
Users browsing this forum: No registered users and 5 guests
