Can't get slow speed jet out
Tried penetrating oil and the sheet metal screw trick and it won't come out. Does this jet have an o ring on it? Will some heat help? Carbs are nice and clean for the most part but this jet is plugged. Thanks for any tips.
Re: Can't get slow speed jet out
Here's one good means: viewtopic.php?f=20&t=6817 Good luck.
thanks allot Larry, the pics on that other thread are awesome. I was finally able to clear the jet but since you can't see the air bleeds it's anyone's guess as to whether they are clear or not. Guess I'll make the tap bushing and pull them all out. Thanks again,daveLarry Zimmer wrote:Here's one good means: viewtopic.php?f=20&t=6817 Good luck.
