Side Cover Pin Repair
Limey01
Post by Limey01 »
When I got this bike one of the locating pins was broken off on the left side cover and it was flapping while going down the road and I was scared I was going to lose it. So I flattened off where the pin had broken and drilled a hole in the little raised boss. Then I made a new pin out of aluminum and threaded the other end, slid a nut up under the boss, a little blue loctite and tightened it all up and it worked like a charm. Quite pleased with myself.
7412
Better to remain silent and be thought a fool than to speak out and remove all doubt.
Re: Side Cover Pin Repair
Wait...."then i made a new pin out of aluminum"....what am i going to do with the 8 different kinds of duct tape that i own?
Nice fix, MacGuyver.
wyly
Post by wyly »
steve murdoch icoa #5322 wrote:Wait...."then i made a new pin out of aluminum"....what am i going to do with the 8 different kinds of duct tape that i own?
I doubt Mcgyver had the means to shape an aluminum pin, just as I don't :( ....I was hopeful of a solution I could manage when I saw "Side Cover Pin Repair" ...but no, I'll still need to rely on velcro to keep the panels on my GS in place
I make sure to keep my 79's pins well lubed with lithium grease to avoid breakage...
Limey01
Post by Limey01 »
Believe or not a lot of my friends do call me McGyver. Of course it does help when you have a lathe in your garage.
Stevo
Post by Stevo »
Great repair I was wondering how to do this, several of my pins are missing, can you tell me if they are all the same? my bike is completely stripped at the moment but I am sure some of the rubbers that the pins were supposed to clip into were elongated not round. 1981 Prolink
For all who have not broken a pin -- yet -- a little silicon grease around the rubber grommet holes does well to prevent breaking them by reducing pull-off force. Haven' lost one doing this.
