Rear master cylinder source?
- icouldabeenav8
My '79 rear master cylinder still oozes despite rebuild attempts. Is there a source for new ones? I notice cheap Chinese ones available for other models but not for 1979.
Re: Rear master cylinder source?
I was surprised to see different numbers when i looked at a parts fiche but the other years will work on your '79.
Once again i think it was Nils that looking into getting the cylinders bored.
- FalldownPhil
I believe you are correct Steve.
Best,
Phil
Best,
Phil
- icouldabeenav8
Thanks, buying a cheapo ebay master cylinder - will report back.
- icouldabeenav8
Well, my cheapo eBay master cylinder experiment is at an end. Theoretically it would work, but after solving one fitment issue after another I decided the work was too much effort. I took another look at my old m/c to see if I could determine why it was leaking before making the final dive into modifying the new one.
Upon disassembly, I found nothing wrong with the new rubber parts. There was nothing wrong with the cylinder bore. Hm-m-m-m. I looked at my near 40-year old original rubber parts I had removed. The old stuff had no cuts, tears, rips etc., so I decided to reinstall my original OEM rubber parts.
After 24-hours , no leaks and the master cylinder is working perfectly! It may yet leak, but at this point, the m/c is vastly better than it was with the new guts. I am sure that Zeus is laughing just waiting for me to relax.
The new rubber parts are theoretically identical to the old rubber parts but in reality they are a few thousandths smaller hence they leak. Happens all the time for me with repairing my older pickup truck. I solved the frustration by upgrading everything I repair.
Rebuild kits for the original M/C s are still available from Honda.
- icouldabeenav8
Still holding.
- CopperCollar
A long shot here but in the past I was able to use the rear master cylinder off a Honda dirt bike. Close as I could tell it was the same as the CBX one but the actuation shaft was different. I was able to use the CBX actuation shaft and the master cylinder was a direct bolt on.
It's been a long time and I no longer have the part number but I think it was to one of the dual purpose bikes.
I am thinking the master cylinder may be the same across the product line with only the actuator rod dictating the part number difference?
Re this resleeving topic, I did have my front MC re-sleeved several years ago by a place called Apple Hydraulics in New York. It worked perfectly, and has ever since, was $100 or so as I recall. They were exceedingly careless with it though, nicks and gouges were all over it when I got it back. Would not use them again.
- icouldabeenav8
Still holding. Success declared.
I had the same problem and bought a new rear master cylinder from Aliexpress for £10. All I had to do was drill the master cylinder top mounting hole to 8mm and tap the bottom one to 8mm. Works a treat.
I came across this information in the 2018 March/April issue of Motorcycle Classics magazine.
Brake and Equipment Warehouse (brakeandequipment.com) in Minneapolis Minnesota will bore out your pitted front or rear master cylinder
and press in a stainless sleeve and hone the inner diameter to OEM dimensions.
