Alternator and oil pressure switch 'boot'
CBX1000chris
Post by CBX1000chris »
Apologies for subject description and if this has been covered before sorry too, I did search for them! I'm working through my bike and the boot for the cables that exit the alternator is badly cracked. Looking at the parts diagram I think this boot is part of the alternator harness. Also, the cover over the oil pressure switch is cracked and appears to be part of the sub-harness. Does anyone know of a source for these or suitable alternatives?
Thanks in advance,
Chris.
jnnngs
Re: Alternator and oil pressure switch 'boot'
Post by jnnngs »
Chris,
I believe the Six Center has them:
http://www.sixcenter.nl/onderdelen/deta ... 4&start=13
Paul.
jt
Post by jt »
Tims also has them. Scroll to bottom of page.
http://www.timscbx.com/
JT In Texas
the mirror every mornin'.
TIMS has them for sure. The oil pressure boot is easy to replace, but the alternator one is a real pain. You have to remove all wires from the connector, then fish one at a time through the new rubber. You'll be cussing by the 3rd or 4th wire.
CBX1000chris
Thank you for the replies, just what I needed :o)
cbx1956
Post by cbx1956 »
jt wrote:Tims also has them. Scroll to bottom of page.
Been out of stock for ages & doesn't know when he'll get again. I checked
Just bought two from Louis.
