starter motor rebuild kit, needle bearing problem
harrimansat
Post by harrimansat »
Hi, I have bougth in Ebay a rebuild starter motor kit.
http://www.ebay.com/itm/280461863216?_t ... EBIDX%3AIT
All parts were ok, except the needle bearing that is a different size, the one that I need is for a 13.5mm shaft, BMT141912A, the one in the box is a HK1312, is too small.
Someone knows where I can buy the correct one, or any solution?
Regards
Miguel
Rick Earle
Re: starter motor rebuild kit, needle bearing problem
Post by Rick Earle »
Miguel did you ever find the bearing you were looking for?
I just bought the exact same kit for my '79 and am having the same problem, a further complication ....I destroyed the original bearing when removing it.
If you found a replacement could you let me know where you got it?
Rick
harrimansat
It is very difficult to find, I think almost impossible. Luckily mine was not broken, and was reused. The easiest way is to machine the shaft to 13mm ... If you find it, let us know!
Rick Earle
Thanks for the quick reply, I have a machinist looking at it right now.
Rick Earle
Thanks Larry, but the bearing we need has a 13.5mm inside diameter, 19mm outside and 12mm deep. The 13.5mm I/S seems to be the deal breaker, I have found it in China but haven't had a lot of success with stuff that I have bought from there.
Lash
Post by Lash »
harrimansat
Hi, at last I have in hand four bearings, F218335, Image, 13,5x19x12 mm.
Regards!
cross
Post by cross »
I got kit from these guys and bearings are wrong size as well. I bought used starter since old one died plus the kit and time to rebuild it, now I'm thinking that i should if gotten new one for $225
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
:auto-sportbike:
