Pipemasters 6-6 - Life is good in the land of Six
Finally got the Pipermasters 6-6 from Australia this week.
Quality and workmanship is excellent. No trouble installing, they fit like a fine glove.
The look is amazing, the sound is unbelievable. "All is now good"
Craig
Dublin, Ohio
ICOA 5921
AMA
AMCA
VJMC - Central Ohio Field Rep.
Pilot ASEL Instrument
1979 Honda CBX Candy Glory Red
1979 Honda CBX Perseus Silver
1979 Honda CBX Black
1983 Honda CB1100F Faster Red (SOLD)
RANS Venterra S-19 N519CS
Dublin, Ohio
ICOA 5921
AMA
AMCA
- FalldownPhil
Re: Pipemasters 6-6 - Life is good in the land of Six
She is better than beautiful Craig.
So very well done.
Best,
Phil
So very well done.
Best,
Phil
Craig, clean off the mantle you will be winning trophies with that beauty.
btw, can i borrow your fan? Going to try a carb synch this week.
isn't cold enuff in the great white north without a fan?
I love that fan, not only cools the engine, it blows away the fumes too!
Craig
Dublin, Ohio
ICOA 5921
AMA
AMCA
Dublin, Ohio
ICOA 5921
AMA
AMCA
- wyly
Because they are a slip-on there is some leakage of carbon. I found that a single wrap of foil heat tape around each pipe helps reduce the blow-by of soot through that last slip joint. Two wraps of the tape was too tight and makes it difficult to get them on and off easily when required for rear wheel removal. The foil tape is like duct tape and serves the same purpose sealing duct work but it's not affected by heat like duct tape is.
Great tip!wyly wrote:Because they are a slip-on there is some leakage of carbon. I found that a single wrap of foil heat tape around each pipe helps reduce the blow-by of soot through that last slip joint. Two wraps of the tape was too tight and makes it difficult to get them on and off easily when required for rear wheel removal. The tape is like duct tape and serves the same purpose sealing duct work but it's not affected by heat like duct tape is.
The first set i acquired years ago had the head pipe, muffler and baffle connections all sealed with red rtv gasket sealer.
What a nightmare.
What a nightmare.
Made my own, hamster cage furnace fan and 1/4 horse motor gotten from a dumpster dive at local HVAC company, then built a plywood box around it. Amazed at how cool the bike stays.steve murdoch icoa #5322 wrote: can i borrow your fan? Going to try a carb synch this week.
- wyly
how am I going to get that into my garage mouse?
