Front master cylinder bore size
What is the limit on front master cylinder bore, I had cylinder with stuck piston so I milled it out and honed cylinder, I had to open it up to .631 to remove all the corrosion, is .006 over too much?
Re: Front master cylinder bore size
According to the service manual, the limit is 15.925mm or 0.6270 inches ID. This would make 0.631 too much.mike209 wrote:What is the limit on front master cylinder bore, I had cylinder with stuck piston so I milled it out and honed cylinder, I had to open it up to .631 to remove all the corrosion, is .006 over too much?
Thanks EMS, I tried to save it but was too corroded, now I have to hunt for good one
mike209 wrote:Thanks EMS, I tried to save it but was too corroded, now I have to hunt for good one
There is a place not far from you called Apple Hydraulics that can resleeve yours. They did mine, and it was perfect and will be for eternity, but they nicked up the MC a lot in the process. Alternatively, you could prowl eBay for something like this, which is cheaper than a rebuild kit!
http://www.ebay.com/itm/Hydraulic-Twin- ... d8&vxp=mtr
P.S. If you do, I'll buy your rebuild kit
Nils, just checked their website, they are asking $95, I think I will take my chance and resleeve it myself,at work I have access to all machinery and tooling necessary for that job, will post result here when done
mike209 wrote:Nils, just checked their website, they are asking $95, I think I will take my chance and resleeve it myself,at work I have access to all machinery and tooling necessary for that job, will post result here when done
Oh REALLY MIke?
How would you like to tool up and do a bunch at the same time?
Lemme go hunt up my thread from when I had this done, I think I have some photos and notes that you might find useful.
Here you go:
viewtopic.php?f=50&t=6393&p=47785&hilit=resleeve#p47785
What I should have said prior was "How would you like to tool up and do a bunch at the same time for fun and profit?"
I think you'd have a few takers if you did.
