Thanks Larry!Larry Zimmer wrote:Steve,
You may need to add a preload sleeve to the forks with those springs. No problem. Use some PVC pipe and a couple large appropriate size flat washers. Use something to cut the pvc square. Have fun. You'll enjoy.
Even though this is the rear shock thread, the fork spring discussion is relevant to the "Handling" category we are in. Anyway, I got the Progressive fork springs for the '82 (Progressive #11-1112) and they come with the preload sleeves and washers. Also comes with a discussion on fork oil level, as well as if the tighter wind goes up or down (doesn't matter).
It will definitely be a good day when I get it out on the road with new shock, new springs and fork oil, and freshly greased bushings!
Steve
