Front Brake Switch Removal
- akinz
Ok what am I missing??? I've removed the screw to try and remove the front brake switch from the master cylinder, but can't seem to budge it.
Re: Front Brake Switch Removal
They stick and you very well might destroy it hammering it out. They aren't terribly expensive.
And, if I remember correctly (me!?) there is a small molded 'peg' that fits into a small recess in the m/c body? Try 'easing' a gasket scrapper between the switch and the m/c body.
- akinz
I ended up getting the switch out. It was a little stuck, but what you do is remove the small retaining screw and what I ended up doing is pushing on the switch plunger then pushing on the plastic body by the plunger with a small slotted screwdriver. Came right out!
