Valve stem hole size on the wheels?
Has anyone put angled valve stems on their wheels? The holes vary in size between manufacturers. If anyone has, what size did you use. Mine is an 82 but the valve stem holes between the years is probably the same.
Re: Valve stem hole size on the wheels?
Never used the angled ones but the regular stem is 11.3mm.
