Thread Index - Carbs - START HERE
This curated list of threads might help researchers with frequently asked questions. Suggestions for additions are most welcome.
Quality carb rebuild kits - 2023: viewtopic.php?f=20&t=12472
DIY carb sync tools: viewtopic.php?f=20&t=12582
Mike Nixon's carb rebuild manual: viewtopic.php?f=20&t=12395
Use of the (controversial) Gunson ColorTune: viewtopic.php?f=20&t=10823
Pods, Stacks or stock airbox?: viewtopic.php?f=20&t=9367
Replacing the throttle pull cable in situ: viewtopic.php?f=20&t=11943
High quality carb screw kits: viewtopic.php?f=20&t=11923
Carb insulators and installation discussion: viewtopic.php?f=20&t=11823
Troubleshooting a hanging idle: viewtopic.php?f=20&t=11692
Accelerator pump adjustment: viewtopic.php?f=20&t=6821
Replacement petcock parts: viewtopic.php?f=20&t=11367
Carb troubleshooting: viewtopic.php?f=20&t=10790
Removing the vacuum "auto valve" (aka "SOS" or "Spawn of Satan" valve): viewtopic.php?f=20&t=10267
Extracting the pressed-iin pilot jets: viewtopic.php?f=20&t=5507
Repairing cracked and leaking float bowl overflow tubes: viewtopic.php?f=20&t=10145
Jetting for pod filters: viewtopic.php?f=20&t=9240
Clearing stubborn pilot jets: viewtopic.php?f=20&t=9559
Removing the anti-tamper "flags" from the mixture screws: viewtopic.php?f=20&t=9481
Carb clamp alternative: viewtopic.php?f=20&t=7495
Prolink vs Twinshock airbox and insulator differences: viewtopic.php?f=20&t=7104
Re: Thread Index - Carbs - START HERE
Thanks for putting these together, Nils.
Nils, thanks for taking the time to put this together, a great resource.
At my seminars this October at the Barber Vintage Days, I'll be discussing probably every item mentioned.
You're the best!
You're the best!
Thank you lads, it was actually a lot faster and easier to do than it might seem. If any of you find a great resource that ought to be included, including things that are not on this site, please just post it here in thread and I shall add it to the post.
These cut aways can be useful.
Excellent, Jeff!
I made this cut-away, thanks for sharing.Jeff Bennetts wrote: βWed Aug 23, 2023 1:07 pmA28F3EFF-5DEA-4636-85FB-A5AC5621CDF4.jpeg
As mentioned in other posts, I will be at Barber Vintage Days this October, giving 2 carburetor seminars, focusing on the CBX.
If you can successfully rebuild the CBX rack, you can do almost any other motorcycle carburetor.
We will provide helpful tricks and tips and handing out samples.
I will also be demonstrating "how to" extract the pilot jets for proper cleaning of that circuit.
Tell your friends.
Do you know your seminar times and location? Museum? Or down there by the food vendor area?
Anytime JR, feel free to post any more pics you may have that might help someone here on the forum get their CBX back on the road.CBX-tras wrote: βThu Aug 24, 2023 8:28 amI made this cut-away, thanks for sharing.Jeff Bennetts wrote: βWed Aug 23, 2023 1:07 pmA28F3EFF-5DEA-4636-85FB-A5AC5621CDF4.jpeg
Tell your friends.
I really do appreciate your contributions too, J.r.
Sorry, none of that has been firmed up yet by Barber. This will be my first time at the facility so, I'm anxious and looking forward to presenting.
I'll update as soon as the information becomes available.
I think all of the seminars since the addition to the museum building was built have been there.
