yeah gotta know what you're doing when changing the geometry, get it wrong and you risk ending up injured or worse. I don't know much so I keep changes conservative and follow what others have done successfully.
CBX 82 project
- wyly
Re: CBX 82 project
Re: CBX 82 project
Thats nice. I will do that if I think it gets to low. Easy fix. I guess i have to see how it is when im done. Thanksbikeymikey748 wrote: ↑Sat Aug 20, 2022 9:35 amI’ve got GSXR 1000 forks and swingarm (same bits as on ‘Busas I believe). Forks are much shorter though solutions exist if you determine that to be an issue for you
http://www.extremecreations.com.au/fork ... -50mm-75mm
In my own case, I have to be mindful of dragging my exhaust collector if I get frisky in RH turns.
The swing arm is longer than the Pro-Link bit, and acts to slow the steering down.
Sorry, I didn’t take notes so I can’t tell you the actual differences lengthwise.
I’ve a steering damper installed, but figure it’s a superfluous addition.
I have never ridden a more stable and forgiving bike. Road irregularities that would have induced all manner of weave/wobble in my Ducati/CBR/SR pass all but unnoticed under the wheels of the Blob. It can’t be made to misbehave no matter how fast you ride either. As well, it can be hustled through corners without working up a sweat, it’s not like you’re on a barge.
I think you will be happy with the results when all is said and done.
- ICOA Rally Director
Re: CBX 82 project
Most, if not all, of the head shake/wobble with the early model can be eliminated by sitting farther forward on the seat. The CBX has about a 50/50 weight bias. Mine shook badly until someone told me to sit forward when riding quickly. What a difference. Of course, when a 300# doofus leans forward, the weight bias changes a good bit.
- wyly
Re: CBX 82 project
I've thought the same and wondered if this was a issue unique to the North America spec CBX. US and Canada CBX have handle bars that are taller and reach further back than the CBX sold elsewhere which raises centre of gravity and shift body weight further back. In conversation with a SBK tuner he said body position is critical, he fine tunes a riders position by small increments. As an example he said the human head weighs about 15 lbs, moving it forward, backward, higher or lower even an inch will have an effect.Rick Pope wrote: ↑Sun Aug 21, 2022 7:53 pmMost, if not all, of the head shake/wobble with the early model can be eliminated by sitting farther forward on the seat. The CBX has about a 50/50 weight bias. Mine shook badly until someone told me to sit forward when riding quickly. What a difference. Of course, when a 300# doofus leans forward, the weight bias changes a good bit.
My head shake has never returned since I converted to lower euro bars . My head shake would be triggered by hitting a dip in the road at high speed compressing the forks so it's also a suspension issue. I installed Racetech emulators as well so it's possible there are several factors at play.
Lower bars, Raceteck emulators, GS1000 swingarm, better (but still not great) shocks and I've not experienced a return to a wobble or shaking.
- Syscrush
Re: CBX 82 project
There are many factors that can play into wallowing, including damping, weight distribution, tire compound and inflation, bike loading, and even aerodynamics.wyly wrote: ↑Sun Aug 21, 2022 9:12 pmMy head shake has never returned since I converted to lower euro bars . My head shake would be triggered by hitting a dip in the road at high speed compressing the forks so it's also a suspension issue. I installed Racetech emulators as well so it's possible there are several factors at play.
When I bought my bike, it had Tomaselli clip-ons, which are significantly lower and farther forward than even the Euro setup. But I also had absolutely, dangerously shot cheap aftermarket shocks and worn out OEM damping rod forks - and that bike bucked terribly over any road irregularity in a straight line, and wallowed frighteningly. It also dove hard under braking, which meant that if I discovered midcorner that I had come in too exuberantly, there was nothing to do but hope for the best.
With the damping resolved, I could make the geometry more aggressive (taking out rake and trail) and move my weight back and up a bit, and still have very stable behavior while remaining responsive. Trail braking on rough pavement is a non-issue now.
Re: CBX 82 project
This sticker was sitting on my window
The bike must have been running in California at one point..
Its from a golf course.
Re: CBX 82 project
More parts today
- wyly
Re: CBX 82 project
Moto gadget Quality tech, installed that on my GS1150efe, it took me awhile before I comprehended how it all worked, very different from oem systems.
Re: CBX 82 project
Yes, have been watching videos from revivalcycles, great youtube videos of alot around building a motorcycle. Beside keyless, this have alot of modes around the lights for thos Who likes that. Alarm system also. And it cut power to less important systems if you are getting low on battery. And built in fuses. Easy wiring.
- Syscrush
Re: CBX 82 project
Hi Theggi, where in Norway are you located?
Re: CBX 82 project
Near Haugesund. What about you?
Re: CBX 82 project
Far north, a small fjord outside Harstad.
Re: CBX 82 project
Allright never been that far north yet, but some day i have to.
