Hi folks, long time no talkie. Also, I'm sorry I missed everyone at Mid-Ohio VMD once again this summer. As hard as I try to get there every year, I'm averaging once every three years lately.
Anywho, I just got the '80 SS back on the road this July for the first time in two years and something curious is happeneing with my mileage. It seems to have gone up by an incredible amount, i.e. From 32>38 mpg. I'm wondering how that could be? While off the road, I did a valve adjust, plugs, wires, Dyna coils, replaced the K&N air filter with a paper one and shimmed the carb needles by 0.040". I also replaced the rear tire, had the rear rotor blanchard ground and cross drilled and rebuilt the rear brake system, but I don't suspect the latter group had anythg to do with the mileage increase.
My logical mind says that the changes I made "may have" contributed to a minor change in mileage, but a 19% increase? Methinks not... What say ye, and as always, TIA!
Surprising increase in mileage
- bdento59
Bill Denton
Yardley, PA
wkdenton@verizon.net
Lazarus Cycleworks, LLC
Yardley, PA
Re: Surprising increase in mileage
Hey Bill, it has been a while.
The "tune up' would contribute some, but likely not that much. But, did you by chance switch to a taller profile tire, thereby raising your effective gearing?
Or, have we gotten older and just don't play quite as hard?
- bdento59
Hi there Rick,
I did change the tire, but not the profile... :<(
Bill Denton
Yardley, PA
Yardley, PA
Hmmm. Wonder why the 32 initially?? Not that much difference between an 80 and an 82. My 82 consistently gets 40. Stock. Makes me wonder if the K&N was 'filtering' a bit much. The only other thing that I can think of quickly would be that the rear brake rotor was doing some dragging that was eliminated by your work there. Unless one of the valves was significantly mis-adjusted. (Somehow I doubt that.)
That is a lot of work an almost everything would help to increase the mileage. Don't discount the effect of a new tire. Lower rolling resistance and (higher?) air pressure will make a difference.bdento59 wrote: , I did a valve adjust, plugs, wires, Dyna coils, replaced the K&N air filter with a paper one and shimmed the carb needles by 0.040". I also replaced the rear tire, !
Personally, I think Bill's getting older, like the rest of us.
Hi ya, Bill.
Knowing how poorly a CBX can run with just an improper air filter, i am not surprised by the increased gas mileage after ALL your maintenance.
