Page 18 of 24
Re: Total Number of CBXes Made
Posted: Wed Jan 27, 2016 11:00 am
by jnnngs
Here's my latest CBX Details.
Frame: 2015553
Engine: 2015665
Build date: 26th Oct 1978 (engine number 3 of the day)
Paul.
Posted: Wed Jan 27, 2016 12:48 pm
Paul, your bike is clearly out of the November production range. While the date on the motor is an interesting bit of information, which was discovered and explained by Tom Battison several years ago, it has absolutely nothing to do with the bike's production date.
Almost all engines were built way before the bike was assembled.
The latest October-built bike I have on record is CB1-20 14973 and the first November bike I know of is CB1-20 14994.
Posted: Wed Jan 27, 2016 2:32 pm
by jnnngs
EMS wrote:Paul, your bike is clearly out of the November production range. While the date on the motor is an interesting bit of information, which was discovered and explained by Tom Battison several years ago, it has absolutely nothing to do with the bike's production date.
Mike,
Forgive me - I probably got the terminology wrong!
I assumed the date on the engine is manufacturing / assembly date of the engine itself.
I have no way of knowing production / build date - no frame plate to record it for UK bikes. But from your data it would suggest it is a November bike given it's only about 500 above your earliest recorded frame number for November.
Paul.
Posted: Wed Jan 27, 2016 4:07 pm
Paul,
I should have said the bike is clearly
from within the November production range. At least that's what I meant to say, forgetting that "out of..range" in English means not from within the range.
At this time, I can say that anything between CB1-20 14994 and CB1-20 17346 is November production. I am adding to that data all the time.
Posted: Wed Feb 03, 2016 9:28 pm
by cross
You probably have my bikes VIN info as i bought it off of member from Phoenix, his name was Dave
My bike is '82 model
VIN:JH2SC0605CC400024 build date 05/81
Engine: SC03E-2400023 build date may 21 1981 (74)
Posted: Sun Feb 07, 2016 3:36 pm
by harrimansat
Posted: Sat Apr 01, 2017 4:10 pm
by LONGCLOSE
EMS wrote:EMS wrote:We didn't have a post in this thread for a while....
As I was just working on the CBX development and production start write-up after another conversation with a former Honda employee, I was able to find more evidence of high VIN numbers.
Ever so often, people refer to the Honda parts book and fiches as a resource for serial numbers. In some of these publications, the end of the 1979 CBX CB-1 or CBX-Z production is stated as serial-no...23175.
I think there is ample proof that this number only applies to the sales region for which the publications were intended for, in this case, the U.S. (or North America)
Besides the fact that we have heard of owners in Europe that own CB1s with VIN-numbers higher than CB1-20 2023175, there now is evidence of the highest number that I will have on record: CB1-20 24200.
Further digging revealed the highest 1979 model CBX (CBX-Z) produced as CB1-20 24590. This was a "European Direct Import" - whatever that means. The last CBX-Z imported into and sold in Germany was CB1-20 24578.
The only other country that received a CBX-Z with a chassis-no over 24000 was France. CB1-20 24315.
So, we may have had the first 1979 CBX in the U.S., but we did not have the last one.
OK so I am about to buy a frame with VIN CB1-2024848 (have the picture from the head stock below) does this mean I will have the highest CB1 ever made? Unfortunately its missing the engine :-(
Posted: Sat Apr 01, 2017 4:16 pm
by LONGCLOSE
Here is the image of the frame number just realised it is 2024248
Posted: Sun Apr 02, 2017 10:50 am
by cbxmel
Longclose,
On my other post I have mentioned that there is here in the UK a Z engine which originated in South Africa CB1E-24624
could this be the engine for the frame as about right gap between the numbers?!
cheers Mel #1876
Posted: Sun Apr 02, 2017 2:27 pm
by wyly
jnnngs wrote:Here's my latest CBX Details.
Frame: 2015553
Engine: 2015665
Paul.
I never knew about that number and I just had a look at mine -3-21-13 ... March 21 1978, engine #13 ?...Frame date is April/78
Posted: Sun Apr 02, 2017 3:00 pm
by jnnngs
Wyly,
The first set of numbers is the production date of the engine: yy.mm.dd (the date is Japanese notation so year 53 is 1978)
the number below is apparently a running count of how many engines built that day.
Paul.
Posted: Sun Apr 02, 2017 3:09 pm
by wyly
good to know, after watching a documentary on the Honda assembly plant I was under the impression the engine and frame would've been made on the same day...probably explains why engine and frame numbers never match.
Posted: Sun Apr 02, 2017 8:34 pm
by LONGCLOSE
cbxmel wrote:Longclose,
cheers Mel #1876
It appears that South Africa was one of the largest markets for the CBX and ended up with some of the last bikes from Japan. My current rebuild project which is a "79" black model which may have been an import from Germany is frame number 2020452, this is being fitted with engine number 2024615. Unfortunately I only came across this frame last week - the engine would have been better suited to that frame number. Unfortunately the registration papers are in the system being processed already for the black bike.
Posted: Tue Apr 25, 2017 8:16 pm
by Irishman1
Hey there, my newest(to me) 79 cbx frame #cb1-20000892 engine # cb1e-2001125
My 81 if you want it is SC0600BC301206 I can't get the engine number right now
Hope this helps out!!
Posted: Tue Apr 25, 2017 9:20 pm
by Jeff Bennetts
Love the old school Kerkers, one the best performing aftermarket 6 into 2 systems available back then and IMHO one the best looking megaphone exhausts too!
