Total Number of CBXes Made
Re: Total Number of CBXes Made
I love the way it sounds, a little bit loud though. But cool!!
ICOA # 6786
Bike in the garage right now:
1979 CBX1000 red
1980 CBX1000 red
1981 CBX1000 prolink
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 sulfur yellow
1975 gl1000 red
1976 gl1000 sulfur yellow
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
1978 cb750f super sport
1979 cb750f super sport
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
- FalldownPhil
Very Nice CBX. Also a low VIN number.Irishman1 wrote:I love the way it sounds, a little bit loud though. But cool!!
Just for curiosities sake, does it still have the original
smooth cylinder studs or have they been replaced with the
spiral ones? There was a recall and service bulletin but there
are still some out there with the smooth studs.
- wyly
recall? ...I never received notice of a recall ...should I expect my engine to self destruct any time soonFalldownPhil wrote: Just for curiosities sake, does it still have the original
- FalldownPhil
Wyly,
I think you will be fine. I have had at least 5 or 6 of them and never had an issue. The service bulletin is dated 5/9/79 and
is service bulletin #3 for the CBX. It has to do with them leaking oil at the cylinder base gasket. The bulletin says to remove the
rear studs and use Hondabond on the lower threads of the studs. The dealerships were replacing the smooth studs with the spiral
ones. As an aside, I have all of the service bulletins from back then from 350cc to the GL1500 in case someone is ever in need.
Kerker had two different baffles available, the street and the race. You may have the street baffle but it might need to be repacked to bring the decibels down a skosh, they should sound throaty but should not drone.Irishman1 wrote:I love the way it sounds, a little bit loud though. But cool!!
If the VIN number is correct, this is one of the last (maybe THE last) 1980 CBX produced.
https://www.ebay.com/itm/1980-Honda-CBX ... =R40&rt=nc
Admittedly, I've only skimmed through the thread, but is there a database somewhere that's accessable?
Vin 400825
Engine 2400801
looks like it was made June 1981 but as a 1982 model
Vin 400825
Engine 2400801
Why do you say "June". Does the VIN plate say so?
All 82s were built in 1981. I have no evidence of any made after December 1981. Actually there is only one case I heard of 12/81. Most "late" 82 models date to October 1981.
Hello,
I noticed from the Membership Survey that my frame number was the highest submitted for a '79: CB1-2024573. The engine number, which I hadn't submitted, is CB1E-2024709. I thought that maybe this was the last '79 manufactured but I found in "The CBX book" by Ian Foster that the highest frame number yet found is 2024590 (Battison study). However, the highest engine number from The CBX book is 24149. Is my engine, or at least the crankcase, then probably a replacement unit or, since the difference between frame and engine number is just 136, could it be the original engine?
Any thoughts?
Pierre
(living in Sweden)
Any thoughts?
Pierre
(living in Sweden)
The "Membership Survey" - if you refer to the original one by Pete Ruff - has long been obsolete. Honda documented the last frame and engine numbers for the 1979 model in their CBX-Z CBX-A parts manuals.
They were CB1-20 24590 for the frame and CB1E- 20 24713 for the engine. The highest frame number was a European Direct sales bike, the highest engine number was a German bike.
Your engine could very well be original to the bike. Both your frame and engine number are within the possible ED bike combinations. Not the last ones, but very late. Production of February 1979.
Great info, as always, Mike!
EMS, thank you for your reply. Yes, I was referring to the ICOA Membership Survey by Pete Ruff.
May I bother you with another question? I have two other CBX’s, one with frame number 2021616, and one with frame number 2004493 and engine number 2004660. The latter one is supposed to be one of the bikes from the first batch (of three bikes) delivered to Sweden. Could it also be a European Direct sales bike since I don’t think that there are any bikes with a Swedish spec?
/Pierre
/Pierre
3Mix: It is not possible to confirm that your bike was one of the first 3 imported to Sweden unless the first owner or selling dealer had some documents accordingly. It is very likely a ED bike, as Honda did not make a bike specifically for the Swedish market, as you correctly say. It is my understanding that "European Direct Sales" bikes were used for those markets that did not have unique requirements and did not have an official Honda organization who would handle import. Bikes were supplied directly by Honda to the dealers.
Newly registered here. 38 year owner of 1980 CBX. I just binge-read the 19 pages of this thread. Great stuff. Looking forward to more,more,more.
My vin plate shows 6/79 mfg. date. #2000546.
The engine shows SC03E 2000477.
Greg
Greg
Welcome, Greg! So, here is a little tidbit. Your engine serial number is lower than the chassis-number. That is not totally unheard of, but still a little unusual.
I have engine serial numbers for 1980 bikes with "500" VIN numbers ranging from 524 to the low 600s
