I have been unable to remove the front wheel axle-nut on my 82 CBX. Originally I tried 22 mm wrench backed on the other end with a 17mm wrench. When that didn't work I purchased a 1/2" drive 6-point 22mm deep socket that can just reach the hex head on the axle nut, I then hit with my 300 ft-lb air impact wrench. No go there either. Currently waiting on some liquid penetrate to soak in a bit.
Could the nut possibly be left-hand threaded? I see no mention of left-had threads in the shop manual.
Any advice would be much appreciated.
ProLink Front Axle Nut Removal
Dave Bell
1982 CBX
2000 BMW K1200LT
1972 Detomaso Pantera GTS
2005 Acura NSX
2008 Roush F-150
1982 CBX
2000 BMW K1200LT
2005 Acura NSX
2008 Roush F-150
Re: ProLink Front Axle Nut Removal
They are not left hand thread. Time for a breaker bar with a pipe on it.
The liquid wrench seems to have helped. After a half-hour soak, the impact wrench quickly broke the axle nut free.
And yes, the axle nut is the mostly normal right-hand thread type.
Thanks for the quick reply.
Dave Bell
1982 CBX
2000 BMW K1200LT
2005 Acura NSX
2008 Roush F-150
1982 CBX
2000 BMW K1200LT
2005 Acura NSX
2008 Roush F-150
I’ve had a hard time with those too, Dave.
Heat with a Mapp torch - it'll come right loose.
